Steam whistle-pitch pipes
Home Forums Locomotives Steam whistle-pitch pipes
  • #617867
    michael howarth 1
      @michaelhowarth1
      Whilst tootling around in the workshop I came across a pitch pipe-brass chromed tubes, just over an inch long and joined together like pan pipes. They make quite delightful sounds which would sound really good on a loco as a whistle. Whilst they work perfectly when gently blown into they refuse to emit any sound when blown into with compressed air. Does anyone with knowledge of these pipes know what needs to be done to convert them into a steam whistle?
      michael howarth 1
        @michaelhowarth1
        #617873
        duncan webster 1
          @duncanwebster1
          Problem is the different speed of sound in air and steam. I wish you luck, but I'm not holding my breath.
          #617874
          noel shelley
            @noelshelley55608
            I'm pretty sure this matter has been discussed in ME at least once, but a few years ago ! Noel.
            #617919
            Nigel Graham 2
              @nigelgraham2
              The clue might be in the question itself: not only the speed of sound (which depends on the density of the medium, not its pressure as such) but the pressure of the air or steam entering the whistle.
              Over-blow a recorder, say, and it emits a harsh squeak at best, and that's just by lung effort.
              #617922
              Roderick Jenkins
                @roderickjenkins93242
                Mick,
                Your pitch pipes are probably for tuning violins (4 pipes) or guitar (6). If so, they will likely be reed pipes rather than a flue pipe as used for steam whistles.
                Rod
                #617931
                michael howarth 1
                  @michaelhowarth1
                  Hallo Roderick. Yes they are reed pipes I believe. Does that mean that they will not work with steam?
                  Nigel. Overblowing the pipe does emit a strangulated squeak of sorts just as in your recorder analogy. The strange thing is that I barely have to breath into the pipe to get a fine mellow note but they will not work on compressed air however low the pressure.
                  Mick
                  #617933
                    Mick
                    Diagnosis at a distance is difficult [!]
                    But I suspect that your “however low the pressure” is still way too high
                    The maximum pressure that your lungs can blow might be around 2psig, so your gentle breath would be a tiny fraction of that.
                    Experiments with a manometer tube might be helpful
                    Edit: __ I have just found a wondrous list on Wikipedia:
                     https://en.wikipedia.org/wiki/Orders_of_magnitude_(pressure)
                    [ Wondrous if you like that sort of thing ]
                    Edited By Michael Gilligan on 20/10/2022 09:01:53
                  Home Forums Locomotives Topics
