steam taxi by Martin Ranson
Home Forums Beginners questions steam taxi by Martin Ranson
Viewing 2 posts - 1 through 2 (of 2 total)
  • #43936
    stevieboy
      @stevieboy
      so how do we fill this gas tank then? do you have to purchase a proper propane valve or can one make the valve, and what sort of gas refill can do you use ,is it the same as you would use for filling a gas lighter? Does the tank have a safety valve? if the heat shunt used is too hot does the tank vent via this vavle or if it gets that hot is it likely to explode?
      stevieboy
        @stevieboy
        filling a gas tank
