Steam ports
Steam ports
Home Forums Stationary engines Steam ports
  • #87168
    Steamshy
      @steamshy
      steam portsI made this twin from a photo but it wont work, I guess that i have put the steam ports in the wrong place, Any advice would be great as I would like to get it running after nearly completing it.
      AndyTwin copy
      Steamshy
        @steamshy
        #87169
        Jens Eirik Skogstad 1
          @jenseirikskogstad1
          Eeehh, no possible to run steamengine with one port, you need 2 ports , inled and outled. See the link: http://www.animatedengines.com/oscillatingsteam.html
          #87170
          Springbok
            @springbok
            Hi Andy
            Where is the steam chest
            #87171
            Steamshy
              @steamshy
              Hi Guys, The inlet port is the hole at the top of the steam chest, exhaust bottom hole,
              centre pivot guide. The piston on bottom of stroke clears the lower exhaust hole.
              #87193
              michael howarth 1
                @michaelhowarth1
                Andy…..sorry, you have got the ports on the stand all wrong. If you google "Animated Engines-Oscillating Cylinder", you will see how they should be arranged.
                #87213
                Sub Mandrel
                  @submandrel
                  You may be able to plug the holes on the standard and redrill as per the links given above.
                  Steamshy
                    @steamshy
                    Thanks guys, I sure guest it wrong in drilling my ports in the position I put them, Not sure if i will just make a new post with regards to the animated engine link. Or blank off thre existing port and re-align them,
                    If it dosnt work will try again and make a new post.
                    Andy
                  Home Forums Stationary engines Topics
