Steam pipe olives
Steam pipe olives
Home Forums Stationary engines Steam pipe olives
  • #3123
    Maurice Cox 1
      @mauricecox1
      Maurice Cox 1
        @mauricecox1
        Is soft solder acceptable for fixing the brass olives on a steam pipe? The pipe in question is 3/8" diameter, and the maximum preasure is 60 lbs/squ. inch.I have silver soldered one on, but they tend to melt!
        #87308
        Sub Mandrel
          @submandrel
          HI Maurice,
          My understanding is that if the stem is wet (i.e. unsuperheated it is unlikely to melt soft solder, but I know it goes weak at well below the melting point.
          If you are melting brass olives when silver soldering them, you are using too much heat I would say.
          mgj
            @mgj
            Yes it will work – for a little while if my experience is anything to go by.
            I built a 3" traction engine and soft soldered all the joints. And after they failed in less than a month, I had to replumb the whole thing. I don't think I have a single original joint remaing.
            So I would stronly advise you to forget the soft solder – unless you enjoy plumbing.
            Comsol might be OK – no exerience, but personally, I have no intention of putting soft solder anywhere near a steam pipe again!
          Home Forums Stationary engines Topics
