Steam engine , to start a steam engine
Home Forums Stationary engines Steam engine , to start a steam engine
Viewing 15 posts - 1 through 15 (of 15 total)
  • #3439
    Steviegtr
      @steviegtr
      A small twin cylinder donkey engine, gets the big bad boy running
      Steviegtr
        @steviegtr
        Thought this may be of interest to members who like full size steam engines. This one is huge.
        Steve.
        Huge steam engine
        Edited By Steviegtr on 15/02/2021 23:38:20
        #527630
        Maurice Taylor
          @mauricetaylor82093
          Hi, most of the factory that built this has just been demolished and a housing estate is being built on the site.
          Maurice
          #527632
          Steviegtr
            @steviegtr
            Posted by Maurice Taylor on 16/02/2021 00:11:52:
            Maurice
            What a shame. Dam houses.
            Steve.
            #527861
            Meunier
              @meunier
              Nice find Steve, is that barring engine a full-size double-10-V ?
              DaveD
              #527867
                Some interesting gear profiles in use:
                old mart
                  @oldmart
                  Those teeth on the big wheel look like steel pins, which would make sense for a gear that was not used often.
                  #527884
                    Posted by old mart on 16/02/2021 21:09:38:
                    Rather like a giant ‘lantern pinion’ in construction yes
                    … but what’s with the gear in the foreground ?
                    [ assuming it is a gear not a water-wheel !! ]
                    Edited By Michael Gilligan on 16/02/2021 21:22:36
                    #527887
                    Chris Chadwick
                      @chrischadwick43059
                      A very, very worn worm wheel.
                      #527893
                      old mart
                        @oldmart
                        That large worm wheel is driven by a worm on the donkey engine crankshaft. Did you notice that there were two donkey engines, only one was needed.
                        #527902
                          Posted by Chris Chadwick on 16/02/2021 21:40:38:
                          That’s what I guessed it must be, Chris … thanks for the confirmation
                          … hence my use of the word ‘interesting’
                          noel shelley
                            @noelshelley55608
                            Forncett industrial steam museuum have a huge triple with an almost identical baring engine, The Dover Engine. Noel
                            #527933
                            Howard Lewis
                              @howardlewis46836
                              Many years ago, there were two large beam engines at Coleham Head in Shrewsbury, which pumped sewage. 114 and 116 gallons per stroke. usually only one engine was in steam at a time. Normally they ran at about ten strokes a minute. "They will do 16, but shakes the whole building"
                              They were barred over, using a crowbar engaged in the teeth on the 12 feet diameter flywheels.
                              Although no .longer in active service in happier times one was steamed each week as a museum piece.y
                              The WaterWorks Museum in Hereford has the oldest operating triple expansion stationary steam engine in Britain. It used to pump water from the River Wye, so that it eventually reached the water tower which supplied water to the city.
                              Sadly, like The WaterWorks Museum, Coleham Head Pumping Station, it is currently closed, but hopefully, before too long we shall be able to go and visit again.
                              Edited By Howard Lewis on 17/02/2021 07:51:17
                              #527934
                                Michael, photos of a barring engine which better show the wormwheel that is driven by the crankshaft's worm.
                                And member Phil P's model of one to go with his Corliss
                                #527950
                                  Thanks for the links, Jason
                                  Yes, I get the idea, but the shape of the worm-wheel teeth in Steve’s video was what intrigued me
                                  … As per Chris, last night, I’m happy to believe that they have done some serious work in their time.
                                  yes
                                Home Forums Stationary engines Topics
