steam engine
steam engine
Home Forums Beginners questions steam engine
  • #224132
    gavin compton
      @gavincompton68796
      Hi all
      i trying to set up the valve timing (slide plate) with a reverser 2 forward 2 reverse and neutral.
      my first and main problem is non stop air from exhaust no matter where slide plate is. i tried pressure up to 100psi.
      i can make the piston move oneway only at very high pressures (80+ psi) i run out of air before it can then make piston return (double action piston).
      ATM piston is not connected to rest of model so the no binding involved and piston move my hand nice and smooth.
      any help in this is very very much welcome.
      Gavin
      gavin compton
        @gavincompton68796
        non stop air from exhuast.
        #224149
          Make sure the slide valve is free to move about on the valve rod. if they stick it prevents the valve seating on the port face.
          Whats the model?
          #224160
          gavin compton
            @gavincompton68796
            Hi Jason
            its the engine that i been rebuilding
            think the problem is i did the slide valve up tight on rod i will give it slack and try again in few days time when i return home.
            thanks
            thats pic of the valve chest
