Hi Steve ,
I need to know more exactly what you are looking for :
A condenser reduces the steam to water and there is no exhaust at all . There may be additional functions in a condenser system to separate oil but only to make the output water clean enough to reuse .
To condense water is easy and there are many practical designs of condenser .
A separator on the other hand filters out the oil from the steam but little condensation occurs and the input steam leaves again still being steam . The filtered oil is drained off usually as a waste product .
Removing oil from steam without much pressure loss is more tricky and the common systems are :
Jet separators , perforated metal filters and containers of very loose spongy material . For exotic applications there are also granule filters and cyclone and centrifugal separators .
Michael Williams .
Edited By MICHAEL WILLIAMS on 09/04/2012 11:24:22
