Stationary Engine Series ME
Home Forums Model Engineer. Stationary Engine Series ME
  • #125016
    Alex Collins
      @alexcollins55045
      Hi. I'm a long time lurker in here. I build an engine most years, mainly stationary from whatever metal I have around. I have been looking for my next set of plans when up pops just what i'm looking for in ME This month. I think it's a cruel and tantelising trick to start a build with nothing to make ! I have been forced to start making round bits of metal the correct Dia for things like the Cylinder (Old bit of Cast Iron sash weight). may someone please give me Patience, but i want it now ! Alex.
      Alex Collins
        @alexcollins55045
        #125044
        Stewart Hart
          @stewarthart90345
          Sounds like you have contracted engineprojectitius
          Edited By Stewart Hart on 20/07/2013 06:40:11
          #125046
            The problem is that if Stew started with some construction somebody else is bound to moan that there is no list of materials, you can't win
            #125146
            Sub Mandrel
              @submandrel
              Don't listen to them. Stew did this on purpose, just to wind you up
              Stewart Hart
                @stewarthart90345
                Posted by Alex Collins on 19/07/2013 18:50:33:
                I'd like to know where you're getting the sash weights from there as scares as rocking horse poo Your'e teasing me with that one Stew
                #125153
                Sub Mandrel
                  @submandrel
                  Constipated rocking horse… the only one I have got is so hard a hacksaw bounces off
                  Gray62
                    @gray62
                    Neil, I had a couple of sash weights that were as hard as hard can be, chucked them in the wood burning stove and built the fire on top of them, left them there overnight with a slow burn and they have 'normalised' to a state where they were machinable. Turned out to be a nice bit of iron after that.
                    If you don't have a woodburner, a charcoal barby will suffice instead Just bury the iron in the embers after a good cook out and see what happens.smiley
                    Graeme
                    #125171
                    John Stevenson 1
                      @johnstevenson1
                      Sash weights, quick check guide.
                      Bang one on the floor and break the end off, if it's a dull even grey all over on the break then keep it.
                      If it's got shiny bits in or shiney all over lob it at next doors cat.
                      When they were made sash weight were the last thing cast from a melt to use the metal up so they can vary from melt to melt.
                      A bit like pit props, the good wood goes for manufacturing, then it's pit props, then it's IKEA.
                      #125173
                      Alex Collins
                        @alexcollins55045
                        The sash weights came form a Reclaim Yard. Paid a copule of £ for em. The crust is always hard as you like. Hacksaw will never touch it. Tipped lathe tool is the only answer. Clean out the old rope. Tail in the hole. Bottom in the chuck and away you go. Just part it off. HSS Tools will not do !
                        #125175
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi, 4 1/2" cutting disc will cut the rubbishy end off and cut the length you want to work with. Using a thin disc is best.
                          Regards Nick.
                          #125221
                          Ian S C
                            @iansc
                            Apart from one that shattered when I dropped it, the weights that I havecut easily with a hacksaw, or the bandsaw. The broken one was too hard for carbide tools, and I don't have a log burner, or Barby.
                            Ian S C
                            #125222
                              I've been buying a few of the CI offcuts that Alan at MJ Eng has had recently. All about 6"x6" and 40-50mm think and around £5 each. At that price you can cut them into square section and then turn round and not worry about the waste. Some of our ME suppliers would be looking at £65 for an similar amount of 40mm sq bar!!
                              J
                              #125250
                              Sub Mandrel
                                @submandrel
                                It's tough to supply model engineers – there's a big difference between offcuts from a major stockholder and being a man with a garage holding a good range of sizes. It could take twenty years to sell nine feet of 40mm CI bar a few inches at a time.
                              Home Forums Model Engineer. Topics
