Posted by Martin Turner 4 on 20/12/2017 02:48:51:
Posted by larry Phelan on 19/12/2017 19:42:44:
The more I read about these rotary converters I think it's the way I may go, the guy that sold me the lathe had a Transwave rotary converter, it was a shame he wanted to keep it.
Another case of yes, no and maybe!
On the up-side rotary converters 'just work'. On the downside, they're expensive, physically big, noisy, inefficient and stupid. (Being stupid may be an advantage!)
VFD's are small, quiet, efficient, relatively cheap and stuffed with goodies. Speed control is a very good thing. On the downside, they can be complicated to set up, may not work with all motors*, generally shouldn't be be used to power more than one motor, and might come with a manual written in Technical Xhosa!
* I've read motors made before about 1970 are somewhat more likely to have weaker insulation and/or suffer damage due to earthing through their bearings due to spiky VFD waveforms. Motors less than 50 years old have better insulation and protected bearings.
Also, multispeed motors are less suited to VFDs.
