I want to balance a 16inch diameter 3 bladed propeller from a launch. I can only do a static balance as I have no equipment to do any other sort of balancing. I guess it weights several Lbs
I intend to take the prop off the boat & turn up a temporary shaft/ mandrel about 400mm long. It will be 25mm with a taper to take the prop so I expect one end will be about 18mm diam. I will not need to thread it if the taper is a fairly good fit. I have not done such a taper before but will search youtube for guidance. Does not need a key
To do the balance I want to make a frame with 4 wheels. 2 overlapping each end. Each one on bearings & as free running as possible. I reckon about 3mm th & 100-125 mm diameter.That should be easy enough on my Warco 240MV lathe
What I am not sure is how far apart to put the centre of the pairs. If they are close together such that the tangents are fairly horizontal they may not rotate. if they are too far apart with the tangents almost vertical they will put a lot of side pressure on the wheels & increase friction then just jam.
So there must be an optimum angle for the 2 wheels to meet so that I get a good friction free rotation to balance the prop.(I think)
What is it?
Does anyone have any experience of static balancing & is this infact the right way to balance the propeller. I know this is an engineering forum but presumably some forumites have had to balance equipment at some time in their careers
I guess that in the water it rotates at max 3000 RPM. At tickover revs (800RPM) it shakes the bearing violently, but begins to run smooth once the engine revs pick up. I expect this is because the diesel engine runs smoother plus the water has an effect as well
Edited By Sam Longley 1 on 28/07/2020 17:25:00
Edited By Sam Longley 1 on 28/07/2020 17:32:46
