Stanley knives
Stanley knives
Home Forums The Tea Room Stanley knives
Viewing 25 posts - 1 through 25 (of 35 total)
  • #779387
    old fool
      @old-fool
      I seem to remember in a recent MEW a discussion about “Stanley Knives” While sorting through a box of junk recently I came across a pad-saw blade designed to fit them. Not seen any advertised for years Are they still made? I recall there were two teeth pitches 1 very course ideal for cutting plasterboard  and a finer g.p. one
      peak4
        @peak4
        Yes is the answer and listed on Stanley’s site, but without photos
        https://www.stanleytools.co.uk/product/0-15-276/stanley-saw-blades-wood-fit-fixed-blade-knives-190-mm
        https://www.cromwell.co.uk/shop/hand-tools/saw-blades/0-15-277-steel-saw-blade-190mm/p/STN5853077H
        Personally I prefer ones that cut on the pull stroke akin to a Japanese saw.
        Bill
        #779408
        Vic
          @vic
          Yes, I’ve got a Bahco one that cuts on the pull stroke. It works very well.
          #779411
          Mark Easingwood
            @markeasingwood33578
            Black ones for metal, silver for wood. Drywall saws have different and harder teeth. Plaster board is very abrasive and soon destroys normal saws etc. Can’t find a wood blade at the moment.
            IMG_20250123_172127460
            #779453
            Plasma
              @plasma
              Sounds a strange name but I have a Silky boy pull saw for garden pruning. Sharp as a tack folding saw its brilliant.
              I remember the Stanley knife saw blades but never used one, never struck me as useful.
              I use a Milwaukee recip saw now for general cutting, but a Milwaukee portable band saw is my favourite saw for the shop, cuts beautifully.
              Mick.
              #779462
              Bazyle
                @bazyle
                The Stanley wood saw was a “keyhole saw”, also known as a padsaw. This is a clue to the reason it was cutting on the push as you didn’t want it to pull out the unsupported wood on the surface of the door. I wonder where mine’s got to.
                #779467
                David George 1
                  @davidgeorge1
                  I modified one of my stanly knives to take a hacsaw blade. It just needs a hole for the hole in the hacksaw blade hole and a capscrew and nut no problem and interchangable to pull or push cut and if to long and you have a pull blade and a push blade.
                  David
                  #779470
                  Mark Easingwood
                    They are/were much used by us Joiners on site.
                    The wood cutting blades are useful if you need to cut a small hole in wall board, (ply/hardboard/upvc), to fit around an electrical back box or similar when boarding out a room, think 1970’s-80’s fake Oak planking etc!! They can also be used to start a cut for a larger hole so you can then use a tenon saw or panel saw. Not many jigsaws around back then, and no cordless tools.
                    The metal cutting version is useful to cut through nails and screws, when removing a timber door frame or window frame, which has been nailed into the brickwork, amongst other uses. Or even cutting through the bolt of a lock with no key!!
                    The Eclipse handle for holding a broken, or new, hacksaw blade are better. Sadly I don’t think they are available anymore.
                    Mark.
                    #779478
                    peak4
                      @peak4
                      #779484
                      Plasma
                        @plasma
                        While sorting through some of my dad’s tools after he died I found a Rawl plug hammer drill. It was cordless and came in a box with a supply of fibrous plugs, very different from the plastic ones we use today.
                        Saying it was a cordless tool is accurate, but misleading. It was a chisel type handle with a hardened tool bit held in a tapered socket. Operation was with a hammer, hitting and turning the handle countless times to “drill” a single hole.
                        My dad underdrew the staircase at our home, installing a false ceiling and battening the walls, using this very tool.  I can’t imagine how hard it was for him, hammering away into engineering brick.
                        What he would have given for my battery hammer drill and rotary masonry bits.
                        I threw out the rawl drill but still have his brace and bit drill which he used for years before Black and Decker became a thing.
                        How would tradesmen cope nowadays if electrickery were to be ereased from history?
                        #779492
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi, this is the one that my father had, for holding broken hacksaw blades.
                          IMG_20250124_071514
                          IMG_20250124_071347
                          Regards Nick.
                          #779500
                          Andrew Crow
                            @andrewcrow91475
                            I still have one of these and three sizes of drill bit and some of the fibre rawlplugs and still remember using it to fix my model railway board to the wall in my bedroom.
                            It took about 20 to 30 minutes to make each hole.
                            Andy
                            #779504
                            Howard Lewis
                              @howardlewis46836
                              Still got one, somewhere.
                              Definitely slow and hard labour, but that was before the happy days of masonry drills and hammer function drills, with or without power cords!
                              #779524
                              Bazyle
                                @bazyle
                                Hang on to the rawlplugs – often needed when the modern plastic thing doesn’t fit. We get a lot of the ‘drills’ coming into the Men’s Shed with collections of tools – every man had one back in the day.
                                #779537
                                Colin Heseltine
                                  @colinheseltine48622
                                  I still have my fathers and grandfathers rawlplug chisels and boxes of fibre plugs. Have used them quite a lot in past. Also have all four of those various padsaws.
                                  #779539
                                    I always prefer my Footprint one, different blades, you can mount them either way so push or pull is possible, adjust amount of stick out which is handy if you are push cutting with little room behind the cut.
                                    pad
                                    These days like most tradesment the cordless multi-cutter has taken over a lot of what a pad saw may have been used for
                                    #779542
                                    Plasma
                                      @plasma
                                      I’m trying to imagine a young couple in their new home with my dad’s tool box.
                                      Maybe that’s why the walls are made of compressed straw.
                                      But I’m told handy men are doing a roaring trade changing light bulbs in our area because people have been convinced ladders are dangerous and they need an electrician to isolate the circuit. God I hot swapped more stuff than I can remember.
                                      #779546
                                      Oldiron
                                        @oldiron
                                        I always go to Screwfix Live when it is on at Farnborough Airport. The Rawlpug stand there usually bring part of their museum along to display. Among the exhibits are many old Rawlplugs that contain Absbestos. They have them sealed in plastic boxes to prevent contamination.
                                        Anyone who still has any of the old fibre Rawlplugs may want to dispose of them responsibly.
                                        #779548
                                        noel shelley
                                          @noelshelley55608
                                          Plasmas comment reminds me ! Last week it took me an hour to change one of those horrible GU10 bulbs, the ones that are completely enclosed, often in a 3 bulb array. Took the fitting down after unwiring as I could not turn or withdraw the bulb. The trick I came up with was to put insulating tape on the front of bulb to give more grip, then I could turn it and pull it out. LEDs seemed a good idea, but they fail almost as quick as the Halogen ones. Noel.
                                          #779587
                                          Andrew Tinsley
                                            @andrewtinsley63637
                                            Showing my age, I used to use the chisel type Rawplug drill to fix curtain rail to areas that had reinforced concrete lintels. I did have a mains drill and tungsten tipped drill bits, but they would not touch the lintels (although fine for engineering bricks!).
                                            In my area the Rawplug “Chisels” were referred to as Jumpers, I don’t know if this was the correct name for them.
                                            Andrew.
                                            #779588
                                            Brian Wood
                                              @brianwood45127
                                              Noel,
                                              I use a valve grinding sucker on it’s wooden handle to do the same, but I like your variation and might just try it next time, it will certainly have more grip than the sucker.
                                              #779644
                                              Bazyle
                                                @bazyle
                                                Jumpers seems a reasonable name in some areas of the country. It is the term used for the chisels used to make holes in stone blocks for splitting wedges.
                                                #779662
                                                Roderick Jenkins
                                                  @roderickjenkins93242
                                                  And also the hammered drills used to make holes in mines for explosives.
                                                  Rod
                                                  #779695
                                                  old fool
                                                    @old-fool
                                                    I too remember the rawlplug jumper tools, don’t know what happend to mine. worth hanging on to, I found the “bit” is the only thing hard enough to split hardened valve seats in old engines, when re-ground. (S1 Land-Rover)
                                                    Bob
                                                    #779793
                                                    Dod Mole
                                                      @georgeclarihew
                                                      I still have my 3 Rawlplug jumpers and some fibre plugs and I remember using the Rawlplastic asbestos loaded cement putty stuff for with the pointed poking in tool that came with the kit to pack the hole and form the screw hole.
                                                      My three Stanley knife handles still get used regularly for assorted jobbies, I find the fixed blade type much easier to use than the retractable types.
                                                      Wonder how many have the slip over blade protector that came with the knife when new, mine is still occasionally seen in the depths of the toolbox.
