I want to make a tool post mounted gringing spindle for my lathe. I have a 6" long ER20 spindle with a 20mm shaft. The obvious bearing options are 7204 (47mm OD) or 7304 (52mm OD). My question is, why do all the standard seemless tubes (for the body) come in sizes that are largely incompatible with the bearing OD?
The standard sizes either have an ID so large it would only leave a 1mm internal shoulder to butt the bearing against (55x45mm tube), or the OD would only allow for a 1.5 or 2mm wall around the outside of the bearing (2" OD tube) Im trying to avoid using solid round bar (say 55mm OD for a 47mm OD bearing) and having to turn most of it into swarf.
