Dear All,
as in topic: i'm doing my firste ever overhaul of live steam loco. So far i managed to diassemble the engine and took the boiler off the loco to clean it and inspect it. Unfortunatelly some of the fittings broke during the attemp to unscrew it from the boiler body
Some question on the materials: i found the lower water gauge fitting is made out of brass however the part that goes into the boiler looks like copper. Is it normal practice?
One of the boiler water feed fitting (check valve) is broken too. Have no taps/dies in imperial system so i'll have to make new threads in metric system – metric fine threads, main pitch i plan to use is 0.5mm (ca 50 TPI) or 0.7mm (ca 36 TPI).
Is it good idea to make the fittings from stainless steel instead of phosphorous bronze/brass/copper?
How about sealing – i found the fitting were probably set with some kind of sealant/glue(?). Is it good practice to use thread locker like Locktite #xxx (xxx is for the correct number – i can't remember now the working temperatures).
After paint stripping i found there are some places covered with soft solder – now i'm worried if these are leaks repairs or what??
Have no idea who built this loco, it is 3.5 gauge Atlantic ca 40-50 years old.
In my country there is literally zero live steam models clubs/inspectors/associations – the only knowledge is from books, forums and internet in general.
I'm happy to hear advices from you, experienced, fellows
Thank you.
