Hi Peter ,
The brick arch in a full size engine has four main purposes :
(1) To increase the length of path taken by the combustion products in the firebox and thus ensure that combustion is more complete before products enter fire tubes .
(2) To protect firetube ends from the worst effects of burning and erosion from the combustion products and to further protect tube ends from burning by direct radiant heat from fire .
(3) To prevent any large lumps of coal from being drawn directly into the fire tubes .
(4) To even out the flow of combustion products so that at least approximately the same amount goes down each tube row and in particular to prevent all the combustion products from taking a short cut through lower tube rows .
There is a further minor benefit of reducing spark emission from the chimney .
An arch fitted to a model would probably give some degree of the same benefits as in full size but I doubt whether it would make much difference to actual efficiency .
One final note – a stainless arch needs to fitted so that as far as possible it is not touching any copper firebox plates and also fitted so that any inevitable distortion does not cause arch to jam or dig in to plates .
Regards ,
Michael Williams .
Edited By MICHAEL WILLIAMS on 29/05/2013 23:53:15
