A farmer friend has been overhauling his Fordson County Crawler . Some of the wheelnuts were seized and had damaged threads , both the nut and stud . Another friend donated two Ford 5000 studs,which fit , but the 5000 nuts are flat faced, which isn't ideal…( they should be taper on the crawler)
"What you could do ..is use some conical washers between the new nut and wheel ? " says I..
" Ahh! Yes, the Fordson Majors wheelnuts are like that …that would do .!! If only I knew someone with a lathe …." says he…with a grin .
So yesterday I made two.. out of a bar of 304 stainless , as it was the nearest size bar I had , 2 " dia , (and it turns beautifully
)and he was delighted and paid me handsomely , even though I said I'd do it for nowt..
Curiously, when I bored them in the lathe , I started with a 10mm drill , and as luck would have it , the first morse 2 drill I picked that looked about the right size , and sent through, was a perfect clearance size for the stud thread…about 3/4" …Hit or miss, it fitted over the thread lovely..and the two long swarf spirals produced , was very pleasing . Must be my best sharp drill !!!
The second washer i made, I hesitated when drilling… Fatal error with stainless innit ? Drill went squeak
the stainless went hard
drill was blunt.. So off to the grinder , tickled it sharp again ..and sent it through the washer . Due to my crap sharpening , it then only produced a single long swarf spiral …but it went through ok…
For some reason it cut undersize ,despite pushing the whole drill through..the stud refused to go through it ! Still , a few passes with a boring bar , and the stud passed through as per the first washer .. and while i was in there , I internally chamfered the bore, a little , both sides..
Was my choice of 304 poor ? He's so pleased , he wants 6 more made !
I'm now thinking though , farmers being hamfisted.. If he does up the nuts with a scaffold pipe..will the 304 deform and compress onto the thread and get stuck ???
The flat nuts and studs are high tensile 8.8..
