St/steel tubeff
St/steel tubeff
Home Forums Materials St/steel tubeff
  • #237012
    clogs
      @clogs
      Hi all,
      I'm looking for some Stainless tube 25mm up to 35mm outside diameter with a wall thickness of not less than 2mm but would prefer 3mm…..
      The reason, I have to make some handle bars for a 1930 Indian, they are quite long and the cables are inside the bars……so with the leverage and the neccesary holes I want them tough…..along with the shocks associated with the girder fork suspension or lack off, they need to be strong…..
      Anyone know of a supplier…..most that I've tried can't help….I've seen the stuff in power stations so I know it exists….
      thanks Clogs
      clogs
        @clogs
        #237015
          M-Machine list 25mm in both 2mm and 3mm wall
          #237020
          Tony Pratt 1
            @tonypratt1
            Surely a mild steel tube of say 3mm wall will be more than adequate?wink
            Tony
            #237134
            clogs
              @clogs
              Thank's Tony,
              chrome is not an option with all the plain holes and the 1/8th threaded ones….with st/st u only polish once…it costs a little more but it's cheaper in the long run…..and if you scratch it the marks just polish out…..
              apart from high stress fixing's I only use st/st…..bit of an addict really addict …..hahaha….actually for the price, it's only fractionally more expensive to use st/st nuts and bolt than the BZP variety, especially up to 8-10mm…..a good place to buy is Screwfix…..pretty much what ever you buy comes from China, that's unless it's the old English threads…most of the time I need specials so just make my own and if you need to shorten a bolt the cut end doesn't rust…….I've just got used to the cost I suppose…remember when you take something apart after a few year's it pay's dividends using st/st as you can reuse them, with the rubbish BZP these days I just throw them away used nuts and bolts….
              .cheers Clogs
            Home Forums Materials Topics
