The world of model and hobby engineering
Forums
Help
Register
Log in
Home › Forums › Stationary engines › ST beam engine
Hello , I am building a Stuart Turner beam engine , I have got to the eccentric Andrew Smith's book says make it off centre by11/64 but the drawing says 9/64. Can anyone tell me which is correct please
Regards Phil
I didn.t know Andrew Smith was eccentric !
I am pleased that you could read the drawings in the book . Mine was too badly printed to do so.
Mk 1 eyeball gave me 5mm eccentric ( 10mm throw ) with a 14 mm between centres operating arm.
If you find that the throw is too big you can easily adjust the length of the operating arm .
Brian C
Might have missed a comma.
Ian S C
true sorry !!!!!
phil
oh yes I see . I could alter the length on the rocking lever to get it right if needed
thanks Phil
Same query – Stuart advise 9/16 is correct.
My Stuart drawings that came with the castings shows 11/16.
Mine seems to run OK on 9/32nds movement (9/64" off ctr)
9/16" would put the hole outside the eccentric
Edited By JasonB on 10/07/2016 15:08:36
Apologies – senior moment.
9/16 and 11/16 should read 9/64 and 11/64
Jason is correct, 9/64 is what Stuart confirmed – they did say that the drawing was incorrectly dimensioned at 11/64.
Home › Forums › Stationary engines › Topics
Started by: notyet in: Workshop Tools and Tooling
duncan webster 1
Started by: SillyOldDuffer in: CAD – Technical drawing & design
Started by: Peter Cook 6 in: Beginners questions
Marcel Jolinon
Started by: Andrew Schofield in: Beginners questions
Paul Lousick
Started by: rjenkinsgb in: Manual machine tools
rjenkinsgb
Started by: beeza650 in: Beginners questions
Rod Renshaw
Started by: beeza650 in: Workshop Tools and Tooling
grubscrew
DC31k
Started by: David George 1 in: Workshop Tools and Tooling
David George 1
Started by: bernard towers in: General Questions
bernard towers
Started by: Lathejack in: Manual machine tools
Nicholas Farr
Started by: Diogenes in: CAD – Technical drawing & design
Started by: Baldric in: Workshop Tools and Tooling
Started by: Graham Horne 2 in: Manual machine tools
Graham Horne 2
Started by: Graham Horne 2 in: General Questions
Julie Ann
Started by: maccecht in: Help and Assistance! (Offered or Wanted)
maccecht
Started by: Vic in: The Tea Room
peak4
Started by: castingflame in: Introduce Yourself – New members start here!
Lee Rogers
Started by: JasonB in: Stationary engines
Diogenes
Started by: JasonB in: Exhibitions, Shows and Club Events
Started by: Philip Wheatcroft in: Locomotives
Alan Donovan
Started by: celso ari schlichting in: General Questions
Started by: Phil Whitley in: The Tea Room
Phil Whitley
Started by: Simon Robinson 4 in: Beginners questions
