Squiggle motors
Squiggle motors
Home Forums Clocks and Scientific Instruments Squiggle motors
  • #653318
    John Haine
      @johnhaine32865
      SQUIGGLE micro motor technology
      One for Michael Gilligan, just the job for microscope stages?
      John Haine
        @johnhaine32865
        #653321
        Jon Lawes
          @jonlawes51698
          How interesting! Small motors are fascinating.
          A few years ago when I was into photography I remember being impressed with Canon's ultrasonic range of lenses. I never looked into it enough to find out if they were genuinely powered by ultrasonic waves as some claimed (which seems unlikely but possible). I guess I know what I'm googling this afternoon.
          #653323
            Excellent, John … thanks for the link yes
            Edit: __ Worth noting that: SQUIGGLE motors are an enabling technology, available only within an M3 Module or custom solution.https://www.newscaletech.com/micro-motion-modules/
            so here’s the shop window:
            Edited By Michael Gilligan on 23/07/2023 09:27:25
            #653327
            Martin Kyte
              @martinkyte99762
              Those piezo motors are very useful for small spaces and are quite cost effective. I’ve used them a couple of times on projects at work for positioning and very fine control is achievable due to the minute step size. You can think of them as tiny powered ratchet mechanisms arranged either linearly or in a ring. Each piezo element is arranged so as to contact the driven surface at an angle. When a voltage pulse is applied the piezo chips action is to move the driven surface forwards and slide back on the return part of the stroke. Think of it as having two different frictions higher in the drive direction. To allow bidirectional movement and to create the other frictional part of the ratchet two rows of piezo motor elements are arranged in opposition.
              Positional feedback, at least on my projects which were microscope stages and filter actuators, is by optoelectronic scales.
              As the motors are essentially piezo chips soldered to PCBs they are very easily designed to make in whatever size and shape you wish. We discovered that the company we used would and did make a motor to our spec as a one off.
              They don’t handle loads except for the force produced in the driving direction so bearings etc have to be designed in to the device that the motor is fitted in.
              For camera focusing rings they could be termed ultrasonic as the piezo chips are actuated at those sort of frequencies. Each ‘step’ is tiny so to move fast the signal frequency needs to be high.
              I was impressed with them.
              regards Martin
              Edited By Martin Kyte on 23/07/2023 10:01:47
              #653330
              Clive Steer
                @clivesteer55943
                For those interested there's details of these motors referred to as" Inchworm" on Wikipedia.
                CS
                #656203
                Charles Harris
                  @charlesharris50898
                  Hi Martin
                  Like your post re the Squiggle motors. I know nothing about these as yet but would to learn for model railway projects.
                  Firstly the double ended shaft model rotary style. Are they capable of about 30 rpm?
                  Can these motors be controlled by a processor like Arduino or ESP32 etc. Run 2 or more at a time.
                  What power supply is required, for onboard item.
                  Basically for driving a small model vehicle or locomotive.
                  For experiementing with.
                  Do you have any example or videos of your project with micro etc
                  Thankyou
                  Charles Harris
                  Retired(79 yo)
                  New Zealand
