Posted by John Doe 2 on 01/02/2023 10:44:51:
Thanks again tor the (sensible) replies.
I will say once more that this is a temporary fix only and I will of course be making a proper fix in due course. The reason I don't want to drain the system at the moment is because it is winter and I don't know what I might find or what horrors might reveal themselves – e.g. dislodging debris built up in partially blocked pipes, like in the photos above.
A potentially simple quick fitting of an extra valve could easily morph into a major production, which I am very keen to avoid just at the moment !
I did not install this system so I don't know how badly, (or if), it was cleaned out and commissioned, and I could potentially put the system completely out of action, whereas it does sort of work at the moment. There is other more pressing work required on the house so I just need a temporary fix. The potential of copper tube cracking is why I am asking you; the experts! The squeeze would not be to pinch the pipe off completely, just restrict it partially.
I also don't want to waste a load of inhibitor by draining down only to have to buy another system's worth of expensive inhibitor in a month's time.
PS, in answer to another question; yes,I have tried different pump speeds, as well as adjusting the balance of all the radiators
Edited By John Doe 2 on 01/02/2023 10:53:55
It's not something any expert can tell you with any certainty. It might split, or it might not, depending on many factors including grade of tube, age of tube, condition of tube, how it is squeezed, level of gunk inside the tube and so on. As you have said yourself, messing with old plumbing can be the genesis of many horrors. All you can do is either drain the system and do it properly, or try the squeezing method and be prepared to quickly drain the system if it splits, either immediately or later on at some unknown point when the weakened metal gives way.
Your choice. Personally, I would not risk it, based on having worked for some years maintaining rotten old pipework in industry and hospitals. See Murphy's Law posted above.
The other question is: Will squeezing a copper tube reduce the flow? As you squeeze the tube top to bottom, it deforms and bulges out sideways, maintaining the same cross sectional area and thus not restricting flow. Until you get to a certain point where it has reached near full width and you start to close down the elongated slot shape left. At this point the copper at the ends is being forced into a sharp bend, much more likely to split.
Edited By Hopper on 01/02/2023 11:20:02
