Square holes
Square holes
Viewing 7 posts - 51 through 57 (of 57 total)
  • #119321
    Ian S C
      @iansc
      If you are worried about square corners, mark out the sqare for the hole, and drill the corners, something like 2 or 3 mm, drill the center to full dia, file the sides of the square into the holes at the corners, done. Ian S C
      Saxalby
        @saxalby
        I was missing the the tool from my Boxford shaper and made a square drive spanner the easy way. Simply bought a socket (any size) with a 3/8 inch square drive and welded / brazed that to a piece of cranked flat steel bar. Been using it for several years now.
        #119351
        Saxalby
          @saxalby
          #119361
          Saxalby
            @saxalby
            #119353
            OuBallie
              @ouballie
              Spanners done!
              Used the shaper for the first time in anger in the process as well.
              Photos uploaded.
              Thanks for all the suggestions.
              Saxalby,
              That solution never even crossed my mind.
              Well, I did use the filing machine and the shaper with my approach, so I at least made a start in learning how to use them.
              Geoff – I must must improve on my stick welding. It's horrid!
              #119363
              OuBallie
                @ouballie
                Spanners done!
                Photos uploaded.
                Saxalby,
                #119373
                OuBallie
                  @ouballie
                  Spanners done!
                  Photos uploaded.
                  Saxalby,
