Square holes
Square holes
Viewing 25 posts - 26 through 50 (of 57 total)
  • #118985
    Bazyle
      @bazyle
      Geoff,
      The excell is supposed ot take special filing machine files 4 in long with teeth in the opposite direction to normal files so they cut on the downstroke. They have a 1/4 or 1/8 round tang. They are no longer made and stocks all used up so it is luck to find some in a car boot sale. You will have to grind part of the file to adapt it. Since the files need to be parallel not tapered the only files that come near still in production are chain saw sharpening files – not suitable for our current job.
      Search the web for die filer under the following mfr names as they are all the same basic design:
      Oliver
      Milwaukee Milwarkee
      Harvey Butterfly
      Harvey model B16
      Bazyle
        @bazyle
        Geoff,
        Oliver
        Milwaukee Milwarkee
        Harvey Butterfly
        Harvey model B16
        #118969
        Bazyle
          @bazyle
          forgot they are called parallel machine files.
          American Rotary Tools Company (ARTCO)
          250 West Duarte Road, #E
          Monrovia, California USA 91016-7464
          (Los Angeles area)
          Tel: +1 (626) 358-8466 | Fax: +1 (626) 358-0076
          Toll Free (USA 48) Tel: (800) 624-2212 | Fax: (800) 624-2210
          This company is listing them but not very clear about shipping. could cost a fortune. I might try ringintg them next week. Or as they have a toll free nnumber one of our American friends might check them out for us.
          #118987
          Bazyle
            @bazyle
            (Los Angeles area)
            #119007
            Bazyle
              @bazyle
              (Los Angeles area)
              #118972
              OuBallie
                @ouballie
                Hello Bazyle,
                When I got the "Excel" in 2006, I scoured the Internet and eBay for suitable files, and managed to score some on eBay in the good old USofA.
                They are the proper files as you described, except for the triangular ones, all the others whether flat, square, round or part round have square 'tangs' – Thanks for the correct nomenclature that escaped me.
                I reckon I was fortunate because I haven't seen any since.
                Geoff – Waiting to take her indoors to Stansted, for her jolly eastwards, when I should be in land of Nod.
                Saw your latest post after posting mine.
                Thanks.
                Geoff – Getting photos ready to upload to album
                Edited By OuBallie on 08/05/2013 23:54:49
                #118991
                OuBallie
                  @ouballie
                  Hello Bazyle,
                  Thanks.
                  #119010
                  OuBallie
                    @ouballie
                    Hello Bazyle,
                    Thanks.
                    #118975
                    Dunc
                      @dunc
                      Harold Hall's MEW article, "How to Make a Filing Machine" part 3 (MEW #163, May 2010) detailed a method of adapting common files to cut on the pull stroke to diminish the tendency of the file to push the work out of the way.
                      This info is also available on his website at http://homews.co.uk/page497.html
                      #118994
                      Dunc
                        @dunc
                        #119013
                        Dunc
                          @dunc
                          #118983
                          OuBallie
                            @ouballie
                            Thanks Dunc.
                            I had forgotten about that series.
                            Perfect timing for my needs.
                            Time to haul those copies out.
                            Geoff – Another coffee before hitting the highway.
                            #119003
                            OuBallie
                              @ouballie
                              Thanks Dunc.
                              #119022
                              OuBallie
                                @ouballie
                                Thanks Dunc.
                                #118993
                                Hopper
                                  @hopper
                                  Drill your hole, mark the square out carefully, stick it in the vice and hand file it to size with a square file and finish off with your three-sided file to get the corners nice and sharp. One hour's work, tops.
                                  Depending on what size hole you are making, 10-inch files should shift the metal fairly quickly for you. You'll have it done before you would get the filing machine set up.
                                  Another alternative is set it up in the lathe with a boring bar type tool with square corner on it and run the carriage back and forth like when doing slotting and gradually bring the tool out using cross slide. Use a small tool and do one corner at a time.
                                  #119012
                                  Hopper
                                    @hopper
                                    #119029
                                    Hopper
                                      @hopper
                                      #119246
                                      russell
                                        @russell
                                        my tongue was rather in my cheek when i proposed blacksmithing methods, but it is a perfectly viable approach. re steel selection, absolutely, plain MS would do for both the drift and the spanner, but any form of hardening will prolong the life. Having said that, I'd probably prefer the spanner to wear than damage the machine it's being applied to. But when one starts to wear, the other probably will too.
                                        russ
                                        #119264
                                        russell
                                          @russell
                                          russ
                                          #119282
                                          russell
                                            @russell
                                            russ
                                            #119263
                                            OuBallie
                                              @ouballie
                                              Hopper,
                                              Thanks for your response.
                                              Your first method is exactly how I would have approached it, if that is, I wasn't in possession of the filing machine, but if my previous examples where anything to go by, the square holes would have turned out anything but square.
                                              The "Excel" leaves the corners nicely rounded using the machine diles I habe, which correspond to that on the nuts/drive.
                                              I've been averse to square corners, that may induce stress/fatigue fractures, ever since a pro engine builder kept repeating that to me, when I was building my racing engines in the '70s.
                                              Russell
                                              You said it with such a straight face, it was pretty convincing
                                              The "Excel" performance was exemplary, once I got used to using it that is.
                                              Today I will put handles on, but have a dilemma:
                                              A cranked handle for the manual ram spanner is a given, but not sure what to use on the crank gear sliding block spanner. It's 4" long and will be used on the other nuts as well, so either a straight handle welded on, or drill the end and fit a shaft, captive or sliding for leverage.
                                              Time to use the grey matter to visualize what's needed at the machine.
                                              Geoff – Recovered from yesterday's far too early a jaunt.
                                              #119281
                                              OuBallie
                                                @ouballie
                                                Hopper,
                                                Russell
                                                #119293
                                                OuBallie
                                                  @ouballie
                                                  Hopper,
                                                  Russell
                                                  #119302
                                                  Ian S C
                                                    @iansc
                                                    If you are worried about square corners, mark out the sqare for the hole, and drill the corners, something like 2 or 3 mm, drill the center to full dia, file the sides of the square into the holes at the corners, done. Ian S C
                                                    #119311
                                                    Ian S C
                                                      @iansc
