Posted by Michael Gilligan on 15/05/2021 17:28:21:
Posted by Clive Brown 1 on 15/05/2021 16:53:31:
Beryllium copper is used for non-ferrous springs.
Not arguing, Clive [you are obviously correct] … but I'm interested to know if there is any useful advantage [except for its high electrical conductivity] over phosphor bronze.
Perhaps the greatest advantage of BeCu is that it can be formed in the annealed state and then heat treated at about 320C to develop the spring properties.
Regarding the hazards of BeCu, this is from a hazard data sheet:
Non-hazardous operations
General handling, stamping and forming, many machining operations, medium temperature
hardening heat treatments, cleaning, plating, soldering and general assembly and disassembly
operations are considered safe and do not require specific controls other than general levels of
ventilation.
It goes on to state that certain grinding operations producing dust in a certain size range can cause a reaction in some sensitised operators.
Rod
