Spring Calculation
Spring Calculation
Home Forums Hints And Tips for model engineers Spring Calculation
  • #393732
    Speedy Builder5
      @speedybuilder5
      I am not promoting this site, neither dissing it, however the video of spring manufacture is more than interesting also look at the FAQs where spring design / specification is explained. Ps, click on the UK flag for English
      BobH
      Speedy Builder5
        @speedybuilder5
        Interesting website
        #394321
        Nick Hulme
          @nickhulme30114
          I find an old copy of Machinery's Handbook more useful, it even gives you good starting points for mandrel size/finished diameter for a wide range of gauges of piano wire.
          #394336
          Martin W
            @martinw
            Wasn't there an article in MEW sometime ago about springs, spring winding and calculations for achieving the required force, or have my grey cells finally petered out ?
            #394345
              A comprehensive series by Linton Wedlock in MEWs 234, 235 and 236.
              Ian Newman 1
                @iannewman1
                Hi,
                For small (model sizes) springs, the "standard" formulae do not work as they tend to be based on simple torsion rather than a helix
                "The Model Engineer's Handbook" by Cain, or "Spring Design And Manufacture" (same author) are your friends in this task
                All the best,
                Ian
                #398054
                John Purdy
                  @johnpurdy78347
                  There was also a 10 part series in ME by Tubal Cain on spring calculations. It started in 1986, Vol. 157, #3783 an ran to 1987, Vol. 159, #3807. While I don't have his book from the Workshop Series I suspect that a lot of the material is the same.
                  Howard Lewis
                    @howardlewis46836
                    If you don't fancy designing and winding your own springs, Peterborough Society of Model Engineers members used to use Vincent Springs, who were fairly local.
                    I found designing springs frustrating. Since having arrived at a spring that would fit into the space, (Open and closed ) with the required rate, and provide the load, only to find that the wire would be overstressed. The next iteration would be within the stress, but would not fit; and so on. So found it quicker and easier to pass the job over to the experts!
                    Not too long ago, there was a good series on spring design, using graphs, in M E W, which would be useful.
                    Howard.
                    #398144
                      Posted by Neil Wyatt on 02/02/2019 12:49:01:
