Spline spanners
Spline spanners
Home Forums Workshop Tools and Tooling Spline spanners
  • #126266
    Iain Gordon
      @iaingordon81374
      Hi All,
      I've got a round column mill that does not have a spindle lock. This makes tightening collets "interesting".
      I've just seen a suitable tool to help with this at this website:
      The only downside is the shipping cost which doubles the cost of the tool.
      Anyone know of a UK supplier? I've had a look at Warco's site (they supplied the mill about 9 years ago) but they do not list it.
      Thanks for any pointers,
      Iain
      Iain Gordon
        @iaingordon81374
        Need a spline spanner for round column mill/drill
        #126267
        David Colwill
          @davidcolwill19261
          It looks like it is laser cut so you could draw it up and get it done over here.
          #126268
          Keith Long
            @keithlong89920
            Looks straightforward enough to make from a piece of flat plate, dill a hole and file the engaging "teeth" to fit. Doesn't need a great deal of precision.
            #126270
              A bit of googling will find other methods of locking the spindle on similar X3 type lathes or just file something to suit.
              I've never had a problem tightening anything in my X3, maybe I've got a strong grip?
              #126273
              Iain Gordon
                @iaingordon81374
                Looks like I'll have to get the drills and files in to play. I've just measured up and the one I linked to is too big. Mine is 22mm od and 17mm root.
                Iain
                #126274
                Russell Eberhardt
                  @russelleberhardt48058
                  This is what I use: **LINK**
                  Russell.
                  #126276
                  joegib
                    @joegib
                    ArcEuro sells a wide range of collet nut spanners — see here:
                    ArcEuro
                    Joe
                    #126317
                    Sub Mandrel
                      @submandrel
                      I don't own an X3 but the picture of the X3 spindle in the Arc catalogue shows a slot in it (for a taper release wedge?) Is there some way of being able to poke a temporary bar into this slot, perhaps through a small but well-placed hole in the side of the head?
                      Neil?
