Thanks everyone – sorry I was a bit unclear. As Andyf says I need a board to sit between the existing (original) control board and the computer. The original control has a manual potentiometer that varies between 0 and 5V. There is a tacho on the spindle with a multi-slotted disc. I want to control the spindle from Mach3 – on/off, speed and do threading (give it a go anyway at a later stage after I have got everything else running ).
The motor is 180V, 3.25A, 0.44 kW. Motor goes up to 5000rpm and the spindle up to about 2200 rpm driven by a toothed belt.
John – I contacted Roy at DIY CNC and he said his board would work for me if the potentiometer went from 0 to 10V – I am not sure if that means it is suitable for me (mine is 0 to 5V) but have asked him. His site indicates that his board controls the speed via an inverter which isn't the setup i have. The Homman site does say that his boards are suitable for motors currently controlled by a potentiometer and another person (David Murray on the Denford forums) who has converted one of these machines has successfully used a Homann board.
Thanks for your help – it is appreciated.
Andy
