Hi
On the band saw I rebuilt with two drive motors one for wood hp 1425 rpm driving a counter shaft and one for metal 3/4 hp 1425 rpm driving a 18 to 1 worm gearbox that drives the counter shaft with "Poly Vee" belts all round
Remove the belt from the worm gearbox for wood and swap motor plugs.
Motor RPM
1425
Saw Spindle Pulley Dia
168
Counter Shaft Pulley Dia
95
Worm G'Box
18 To 1
Band Wheel Dia mm
360
Metal Cutting
Motor 1 Dia mm G'Box Dia
53 90
63 80
70 70
Wood & Composites
Motor 2 Dia mm CShaft Dia
50 90
62 80
69 70
Metal
Metres Min
29.82
39.87
50.63
Wood
Metres Min
506.30
706.29
898.33
Sorry about the Layout Just cut and pasted from an XLS Spreadsheet Used to find optimum ratios and pulley sizes
May be useful
Still toying with using a 1.5 hp DC motor and KB Electronics Controller and two speed pulleys.
Though two speed may not be needed as KB quotes up to 50 to 1 speed control and up to 120% max motor speed.
And 0 to 30% min speed on trimpot adjustment of controller.
Not the cheapest option DC drives. Mine is a Totally Biased opinion as a "DC Drive" and "Poly Vee" belt transmission addict.
Eric
Edited By oldvelo on 30/09/2014 04:10:54
