Evening chaps!
As a person who lurks a lot, I feel that it's time that I add my first post that may prove to be of use to someone.
I have repaired my own C3 FC250J control board several times over the 12+ years that I have owned it. In fact, I have just finished repairing it again after it surviving for just one day! I too have had a flash-bang on several occasions, including the past two failures. Close examination and careful troubleshooting has revealed nothing pointing to the root cause… Until now…
Today I decided to remove the Toggle Forward and Reverse switch after testing it thoroughly with no signs of failure and dismantle it (it was the last thing I touched on Sunday's failure with a flash-bang, after using the lathe for several hours), Within the switch, I found clear black sooty evidence of contact arcing. On closer examination I could see tiny pieces of swarf along side the contacts in the switch. Examination with a magnifying glass revealed some tell-tale pitting in the switch's insulation where I assume that swarf had vaporised. So if my deduction is correct, swarf has entered the switch body over time through the switch's open neck, eventually building up to form a bridge across the switch's forward/reverse contacts (the centre two contacts on my toggle switch). So when you flick the Forward and reverse switch you get an instant short with a flash-bang that destroys the MOFETs and the swarf is vaporised leaving a perfectly functioning switch… Until the next build up of swarf!
I have cleaned and reassembled the switch carefully, refitting it to the case after replacing MOFETs (again). The controller is functioning well on the bench. I will refit it to my lathe tomorrow.
As my lathe never had a waterproof cover fitted to the forward and reverse toggle switch, I shall purchase one and fit it as soon as possible. I advise others to do so if their lathes have the same type of switch and those who have the cap fitted ensure that it is in good order! Hopefully such simple remedy will prevent swarf entering through the open neck and causing the momentary short across the switch contacts and destroying the MOSFETs again.
I suspect that this is why Sieg has fitted rotary switches to some newer models of the lathe.
Hope the above helps someone out there.
Kevin
