speed control pcb for Clarke CL300 lathe
Home Forums Manual machine tools speed control pcb for Clarke CL300 lathe
Viewing 226 post (of 226 total)
  • #601879
    jacek nowak
      @jaceknowak11831
      Hello, I would like to ask for help.
      I have the FC250J / 230V model
      I have the module itself where it was shorted until I had to repair the paths. I replaced the 12v zener diode, capacitors c9,13,14.
      After starting and changing the switch (left-right rotation), the motor output is + 110V or -110V (measured by the meter). However, when I turn the potentiometer, the voltage does not change. Should it be like that?
      I don't know if my google translator will translate it well smutny
      Greetings to all.
