Speed and feed rate for 1 1/4″ Carbide Index tool?
Home Forums Beginners questions Speed and feed rate for 1 1/4″ Carbide Index tool?
  • #4927
    Alvin Schlitter
      @alvinschlitter80339
      Please give me your thoughts
      Alvin Schlitter
        Hello All;
        I just received a new 1 1/4″ indexable insert cutter for my ZAY7045FG/1
        Milling machine. Are there others that have a similar tool? What I would like is the speed at which one should run the tool at as well as the advancement rate of the material against the cutter.
        According to  Harold Hall in his book, Milling: A Complete Course  #35; he recommends a speed for 1/2″ HSS cutters at 500 RPM. Based on this a 1 1/4″ (31mm) diameter tool one should use a speed of around 200 RPM. However this is a carbide tool and one can double the speed or more.
        I tried a speed around 400 RPM and the machine seemed to hammer a bit, I raised the speed to around 600 RPM and it sounded much better.  I checked the
        tool and material after dry milling a fairly deep and wide cut and both where fairly cool.
        Please provide you thoughts!
        #47653
        Eric Cox
          @ericcox50497
          What material are you cutting ?
          #47663
          Circlip
            @circlip
            Don’t forget the NUMBER of teeth on the cutter Alvin.
              Regards  Ian.
            #47678
            Alvin Schlitter
              This particular cutter has 2- Inserts in the head, the material that I most often cut is low carbon steel!
              #47683
              Ian S C
                @iansc
                Alvin this won’t be much help,but when I bought my mill,and got a 50mm,3 insert cutter I asked the salesman what feed rate and speed and depth of cut I should use,he said give it a couple of mm cut at 900rpm,and crank like hell.I usually try for a 1mm cut at 540rpm,and I could not quote a feed speed,I just go by feel,afraid all I know is what I taught myself.Ian S C
                #47685
                Eric Cox
                  @ericcox50497
                  Low carbon steel has a cutting speed of approx.300 fpm. dependent on hardness with a carbide cutter .
                   rpm = (fpm * constant)/cutter dia.
                   = (300*4)/1.125 = 1066 rpm
                  #47713
                  Ian S C
                    @iansc
                    Going by that figure I’m not too far away,the figure for 2″-50mm = 600 rpm, my 540 rpm is not too bad,and a bit better than the 900 rpm quoted to me by the “expert”!Ian S C
                    #47726
                    Circlip
                      @circlip
                      How would the machine cope with 1066RPM and 1/4″ depth of cut??
                         ——- Walkies???
                           Regards   Ian.
                      #47727
                      Eric Cox
                        @ericcox50497
                        Look at these for info on speeds and feeds
                         Oh, by the way circlip, weld the machine to a metal table, bolt table to a concrete plinth. QED.
                        Edited By Eric Cox on 23/01/2010 11:22:00
                        #47728
                        Circlip
                          @circlip
                          Wish there was a thumbs up Smilie on this Forum Eric.
                             Regards Ian.
                          #47734
                          Martin W
                            @martinw
                            Ian
                            Nuff said
                            Martin W
