spark eroder
spark eroder
  • #77606
    norman royds 1
      @normanroyds1
      Hello
      Does anyone have details of design of the mechanical part of Mike Napps spark eroder. That was on show at the recent Warwick Show
      Norman
      norman royds 1
        @normanroyds1
        #77609
        Gray62
          @gray62
          Hi, if you are a member of SMEE, Mike will gladly share the details of the device.
          This is not a simple design and requires the programming of a microprocessor.
          It is a very efficient design however, there is another route.
          Ben Flemming has produced 2 designs for an EDM, one is RC based and the other is a more advanced pulse design, both of which use readily available components and do not require a micro or any programming.
          Search Yahoo groups for EDMHomeBuilders for more details or PM me, as I have both of the books and PCB’s in build if you require any further info
          regards
          Graeme
          #77617
          Keith Wardill 1
            @keithwardill1
            Not sure if I have the correct reference, but Mike Kapp (with a K, not N), published a simple EDM design here not long ago – I built a version which works well enough for me.
            It is not a processor controlled system – uses a simple CMOS control circuit. The series of 4 articles gives all constructional details, and the thinking behind it, if you want to change things.
            #127863
            Jack Knapkin
              @jackknapkin40105
              I have seen similar postings for a while now and have tried to build my own machine without success. I came across Pear Tree Engineering ( http://www.sparkeroding.co.uk ) to whom I posted a shaft with a broken tap which they removed sucvessfully.
              It seems an easier and cheaper way than trying to build a machine whose performance may be doubtful.
              Hope information is useful, Jack
              #127880
                Posted by wotsit on 10/11/2011 16:39:37:
                Unfortunately, that link is returning 404 [File Not Found]
                  Probably as the post is 2 years old!! MEwebsite has been changed about recently with a lot of projects taken off and only available on DVD
                  #127892
                    Thanks for the info. Jason
                    Dunc
                      @dunc
                      "…lot of projects taken off and only available on DVD"
                      Hoping – and I apologize for my intrusion on the thread – the moderator would provide details about the dvd (what it is, contents, how to order, cost, etc). Thank you
                      #127911
                        PM sent
