When we were apprentices the South Bend book was referred to as "How to Ruin a Lathe" and there were a couple who seemed to take it to heart.
On setting the top-slide to 30-degrees for screwcutting UNF etc, you get the same effect by leaving the top-slide in the "normal" position parallel to the lathe bed. Then for every thou you wind the cross slide in, advance the top slide by half a thou. So if taking a 5 thou cut, advance the top-slide 2.5 thou.
For BSW etc, use a 55 degree tool and follow the above procedure but deduct a gnat's whisker of advance from the topslide.
