Sourcing an elusive Rubber-Ring!
Home Forums Materials Sourcing an elusive Rubber-Ring!
  • #435617
    Andre ROUSSEAU
      @andrerousseau66124
      Hi, I'm trying to track-down what has, so far, proven to be an elusive rectangular-section rubber ring of 36mm O.D. x 28-30mm I.D. x 5mm thick.
      This is not available via regular inquiry in New Zealand yet I am confident that there is one here. It will likely be amongst the inventories of the automotive/truck/motorcycle spare-parts trade, probably to be found in obscure places in vehicles, e.g. washer bottles, light escutcheons, etc, etc. However, if you can't quote a part number no-one will even bother to look on the shelf so this line of inquiry is a waste of time.
      Does anyone mess about with these vehicles for whom a ring of these dimensions rings a bell? A location-description, vehicle model type and year would be the minimum information I want. A specific part-code would be Christmas and New Year as well.
      Any offerings? Cheers.
      Andre ROUSSEAU
        @andrerousseau66124
        Sourcing Leads required…..
        #435618
        Paul Lousick
          @paullousick59116
          Andre.
          Rings with a square or rectangular section are normally called "washers". A quick search found this site but not in the size that you require. **LINK**
          Try searching under rectangular section rubber washers, or similar description.
          Paul
          #435620
          Old School
            @oldschool
            You can make them by trepanning them out of rubber sheet.
            #435621
            Bruce Edney
              @bruceedney59949
              You could try these guys – They say they custom make
              Ali expres seller
              Also have you tried Seal innovations?
              Bruce
              #435633
              Robert Atkinson 2
                @robertatkinson2
                Hi,
                Sounds like a brake caliper piston seal e.g.
                http://www.ebay.co.uk/itm/for-Vauxhall-Astra-Meriva-Rear-Brake-Caliper-Repair-seal-Kit-Lucas-36mm-3627/274056153625
                Holden Astra down under.
                Try talking to the ebay seller BigRed, I've found them very helpful.
                Robert G8RPI
                #435664
                Howard Lewis
                  @howardlewis46836
                  Since you are looking for a seal, it would probably be described as an 'O' Ring.
                  If circular section it sounds like you are looking for a 26mm Ring x 5mm section. O rings are usually quoted on the ID.
                  You may be able to find a rectangular section one, again, seems that your search is for 26 mm x 5mm scetion, but square, rather than circular.
                  A company that supplies seals and O rings is the place to go.
                  HTH.
                  #435671
                  Nick M0NPH
                    @nickm0nph
                    Your local Caterpillar dealer may be able to help as a lot of cat machines use square section o rings
                    in hydraulic fittings
                    Nick
                    #435678
                    Oldiron
                      @oldiron
                      These may be able to sort you out. Polymax They sell by the metre. You can then make any size you want.
                      regards
                      #435724
                      I.M. OUTAHERE
                        @i-m-outahere
                        The rubber seal or gasket from a 1 inch camlock fitting would be close to those dimensions . Try rubber supplies or retailers , here in OZ we have places like Clarke rubber that sell all sorts of o rings and seals .
                        You could also buy some rubber sheet of the appropriate thickness and type and cut out the size you want ,Making some gasket punches to suit is pretty easy .
                      Home Forums Materials Topics
