Sourcing a small spring
Home Forums Help and Assistance! (Offered or Wanted) Sourcing a small spring
  • #221968
    John Hinkley
      @johnhinkley26699
      I originally buried this request in another thread and not surprisingly got no response, so I'm putting it here, as well.
      Work is progressing – slowly – on my automatic boring head, and I'm looking ahead to when I can start putting it together. However, I will need a small compression spring of specific dimensions. Although they are available from the likes of Lee Springs and Flexo, the cost of postage and packing/minimum order charge means I will have to pay in the region of £20 for 5 springs!. I was hoping that somebody can point me in the direction of a supplier who will send me one or two springs for the cost of a first class stamp and envelope. I've tried all the usual suspects but to no avail and an ebay search only throws up generic springs or boxes of assorted ones. The size I need is free length = 15 to 20mm, internal diameter = 4.1 to 4.5mm, solid length = 8.0mm, wire size 0.8 to 1.0mm. Flexo No. BM-1937-2M or Lee spring LC035C04S.
      Or, maybe you have something suitable in your workshop that I can have in exchange for some beer tokens?
      Thanks,
      John Hinkley
        @johnhinkley26699
        #221969
        Brian H
          @brianh50089
          I've had similar problems in the past but a local spring manufacturer ,www.ashfieldsprings.com have always been very helpful and supplied the odd spring as a free sample. Might be worth a try.
          #221974
          Chris Evans 6
            @chrisevans6
            I have had odd springs wound in Brum for the cost of a drink. I am 30 miles away so by the time I've travelled there and back not much saving but worth it to get the right spring.
            #221976
            Clive Hartland
              @clivehartland94829
              I cannot find those springs in the Flexo cat. nor in the Lee cat. ? I was trying to check the full spec as I may have some. Both web sites say, not found.
              #221983
              Circlip
                @circlip
                Could always wind one 40mm long and cut it in half.
                Regards Ian
                #221984
                Bubble
                  @bubble
                  Hello John
                  Velocette clutch springs are 4.5 id, 1.1 wire diameter, 30 long
                  can be shortened and will give your solid length as 8 turns are 20 mm free length
                  Obtainable from Grove Classic Motorcycles (no connection) at 50p each plus postage
                  Their reference is C12/4 (Venom,Viper, Mac etc)
                  Jim
                  #221985
                  peak4
                    @peak4
                    Just been having a look through my boxes of springs, and didn't find anything suitable. However, I did spot a windscreen wiper arm tension spring about the correct size.
                    How about a trip to your local car spares for one, and then stretch it suitably so make it a compression spring?
                    #221989
                    Dave Daniels
                      @davedaniels93256
                      If you download the 'Polly' catalogue, there is a list of stainless spring stock in 12" lengths on P58 (?)
                      Maybe something there suitable ?
                      D.
                      #221995
                      Nigel Bennett
                        @nigelbennett69913
                        I'm typing this one-handed. The other one contains four springs, Lee LC-035C-04-S. If you will email me at Nigel at PK dot co (and another dot) uk, with your address, I'll put 'em in an envelope for you!
                        Nigel
                        #221999
                        John Hinkley
                          @johnhinkley26699
                          Thank you all for your replies and leads. I'll file them away for future reference.
                          Nigel – you're a star! I'll email you with my address.
                          Regards to all,
                          Tim Stevens
                            @timstevens64731
                            Well done – so quickly that my offer to send him some wire to wind his own would be too late …
                            Regards, Tim
