Posted by Dusty on 28/07/2017 20:52:48:
Its only function is to prevent tooling dropping out of the spindle taper
Not quite; the drawbar also needs to ensure that the taper is tight enough to allow it to transfer the motor torque to the cutter.
On my horizontal mill, which is INT40 with drive dogs, then agreed the drawbar is there only to stop the taper falling out. I would assume that a spindle with a shallow Morse taper doesn't need much tightening to transfer the drive torque. However, on a R8 spindle then the drawbar does need to be pretty tight to prevent the taper spinning under cutting loads. Been there, had that happen; and have had tools work their way out of the collets if not tight enough.
Having said that all my drawbars are low/medium carbon steel, although the CNC mill was transformed by making a silver steel washer to go between the drawbar and the top of the spindle.
