Source of Machined Nuts
Home Forums Materials Source of Machined Nuts
Viewing 25 posts - 1 through 25 (of 28 total)
  • #409683
    Alain Foote
      @alainfoote90915
      I am looking for a supplier of machined 1/4" BSF Nuts rather than the rather mishaped cold formed nuts that most suppliers seem to stock.
      Alain Foote
        @alainfoote90915
        Supplier of Machined 1/4″ BSF Nuts
        #409687
        Anonymous
          Plenty of suppliers for machined BA and small metric nuts but not so for BSF. I've been caught by a supplier advertising machined BA nuts sending cold formed BSF nuts. I wanted the old style thicker nuts, so I made my own, 1/4" BSF full and lock and 5/16" BSF full:
          #409688
          Alain Foote
            @alainfoote90915
            Yes that might be the final solution for me too Andrew!
            Edited By Alain Foote on 17/05/2019 19:46:16
            #409698
            Swarf, Mostly!
              @swarfmostly
              Andrew,
              Do I remember rightly that you have a dedicated repetition lathe? It might interest some members to recap on such a machine's capabilities?
              Best regards,
              Swarf, Mostly!
              #409700
              colin brannigan
                @colinbrannigan54160
                Nookys Nuts online shop stock BSF/ cycle nuts, I use them on my motorcycle rebuilds, good quality. They are zinc plated.
                Colin
                Edited By colin brannigan on 17/05/2019 21:09:03
                #409702
                Alain Foote
                  @alainfoote90915
                  Thanks Colin, really want unplated ones though.
                  #409714
                  JohnF
                    @johnf59703
                    Are these chaps any good ? Accupro, **LINK**
                    #409720
                    Mark Rand
                      @markrand96270
                      0.445" AF hexagon steel is available from a number of suppliers, some on EBay or locally, Acenta in Paynes lane (although, the last time I looked, they weren't as friendly towards orders of smaller quantities (less than 1 tonne, unlike when they were Macready's). Might still do single bars…).
                      Haven't got a 0.445" hex collet, but the three-jaw will work for a limited value of working. Get me a bit of bar and I'll churn them out for you on the HLV.
                      For small quantities, it might be worth tapping some round stock, then milling/surface grinding it to hexagon, before parting off. Or vice-versa.
                      Edited By Mark Rand on 18/05/2019 03:04:05
                      #409727
                      Alain Foote
                        @alainfoote90915
                        Not sure if the Accupro ones are really machined nuts, does anyone know?
                        #409729
                        vintage engineer
                          @vintageengineer
                          If you make up a saturated solution of table salt and malt vinegar, soak them in this and it will remove zinc plating overnight!
                          Posted by Alain Foote on 17/05/2019 21:12:39:
                          #409733
                          Anthony Knights
                            @anthonyknights16741
                            I used B&Q brick cleaner (Hydrochloric acid) to remove zinc plating when I wanted to blacken some nuts. You also end up with zinc chloride solution (killed spirits). Useful for soft soldering.
                            #409741
                            John Hinkley
                              @johnhinkley26699
                              Not knowing where you are on the planet, it's difficult to advise, but, when I lived in Leighton Buzzard, Beds, a couple of years ago, I helped a friend who was rebuilding a Lotus Elan with some machining for the window winding mechanism. This involved sourcing some odd flavoured specialised captive imperial nuts. I went to a local firm. I think it was these people :
                              Alfast Fixings
                              I offered a contribution to their tea fund in exchange for 40 of the nuts. No paperwork involved. You miht be able to persuade a forum member living nearby to visit for you?
                              I suspect if you want thousands, they'd be willing to take your money, too. There doesn't seem to be a type of fastener they don't manufacture.
                              P.S. It might equally have been : Astraeus Fasteners Ltd, Milton Keynes, but I can't find a web site, although the Google Earth location looks vaguely familiar.
                              #409745
                              Anonymous
                                Posted by Swarf, Mostly! on 17/05/2019 20:58:30:
                                Correct, I bought it locally from a two man band that were retiring.The lathe is a Britan, made in Cambridge, probably in the mid 1960s. Here's a picture with the key components annotated:
                                It's quite a small machine, about the same footprint as a Myford ML7, but weighs about 1500lbs. It's similar to a capstan lathe, but is more versatile and is intended for mass production of small parts. Note that the tools are behind the work but the right way up. In normal operation the main spindle rotates clockwise. There are no dials or DROs, everything is done using adjustable stops. In industry the lathe would have been set up by a skilled man and then run by operators on piece rate.
                                The lathe has a two speed reversing motor; speed and direction changes can be made on the fly, no need to stop and start the motor. There is also an auxiliary motor that drives a coolant pump, a hydraulic pump that provides auto traverse and an air compressor for the bar feeder.
                                The lathe is collet only, I have the larger 1-1/4" version. The collets are dead length meaning the material doesn't move axially when the collet is closed. The collets are similar to the DIN6343 but are not standard, by coincidence this is a 0.820" hex collet for BSW:
                                Like all lathes of this type they are pretty much useless without tooling. Fortunately my example came with a significant number of collets and accessories. And I've managed to buy more tooling via Ebay. More collets are always useful, although I've got nearly a full set of imperial rounds. Here are some accessories:
                                I haven't used the lathe to anywhere near it's full potential but I've made most of my own nuts, bolts, washers, studs and threaded "rivets" for my traction engines:
                                I'm currently using the Britan to shorten steel rivets before using them on the rear wheel strakes.
                                Edited By Andrew Johnston on 18/05/2019 10:47:44
                                #409758
                                Alain Foote
                                  @alainfoote90915
                                  That's a very useful looking machine Andrew! Thanks for all the inputs so far. I am in Rugby so not far from MK.
                                  #409761
                                  Paul H 1
                                    @paulh1
                                    Andrew, have you made any collets for this lathe yourself?
                                    #409883
                                    Mick D
                                      @mickd41895
                                      Hi
                                      Acme Stainless supply machined BSF nuts
                                      Regards Mick
                                      #409896
                                      Swarf, Mostly!
                                        @swarfmostly
                                        Andrew,
                                        Thank you for your very full response to my suggestion.
                                        Best regards,
                                        Swarf, Mostly!
                                        #409941
                                        Alain Foote
                                          @alainfoote90915
                                          Thanks Mick for the ACME Stainless suggestion, really want mild steel unplated.
                                          #409974
                                          Anonymous
                                            Posted by Paul H 1 on 18/05/2019 12:33:50:
                                            I haven't, although some of the odder size collets I have look they have been locally made rather than purchased. It wouldn't be too difficult to make a collet if required. The main issue would be forming the hole if not round.
                                            Edited By Andrew Johnston on 19/05/2019 20:55:34
                                            #410455
                                              I was just looking at Little Samson models and noticed this link to Historic Threads they have some nice looking nuts fully machined from round stock as well as other goodies.
                                              #410494
                                              Alain Foote
                                                @alainfoote90915
                                                Thanks Jason, ordered some this morning from NES, not cheap, but hopefully will look better than the cold formed ones!
                                                #410552
                                                Harry Crowther
                                                  @harrycrowther39896
                                                  Maybe try Accu : **LINK**
                                                  Harry
                                                  #410554
                                                  Alain Foote
                                                    @alainfoote90915
                                                    Thanks Harry, I did spot those, but although picture suggests machined there was nothing to confirm this! As stated earlier I have ordered some from NES now.
                                                    #410557
                                                    Anonymous
                                                      Posted by Alain Foote on 23/05/2019 11:23:12:
                                                      ………but although picture suggests machined there was nothing to confirm this!
                                                      The picture is a CAD model; probably little resemblance to reality. At the price I'd be surprised if these nuts were anything other than formed.
                                                    Home Forums Materials Topics
