My 3D printer is a noisy beast and as well as irritating me, it stops SWHMBO from enjoying her serial killers (in the quiet bits) in the lounge above my cellar.
So I had a go at making an enclosure. The printer is a Prusa I3 clone (from Factory3D) and I made the enclosure out of (mainly) what I had on hand.
The base is 12mm MDF, the sides, back and top are 12mm pine tongue and groove panelling and the front is a mixture of some 5 mm ply and a door made of some rexroth 20mm strut with a 2mm perspex sheet (so I can see when it goes wrong …). Sides, top, back and the non-door part of the front are covered in 25mm acoustic foam (basically sponge with grooves in). It's 50cmx50cm square and about 65cm high.
I am getting some attenuation. With the door shut I'm getting about 45dB (measured by my phone). With it open, I see about 55dB. I didn't measure before I put it in the box, but I would think I'm seeing at least 5 – 10dB just from being in the box.
But it's still noisier than I'd like.
Is there anything I can do (cheaply!) to improve this? I've tried throwing a blanket over various parts but it seems to make little difference. Should I have put more battens in to stiffen the panelling?
Or anything else!
Thanks in anticipation
Iain
