Sorting brasses and bronzes etc.
Home Forums Materials Sorting brasses and bronzes etc.
  • #84458
    Colin G
      @coling
      I would like to sort out my small stock of brasses. What is the best / most reliable method
      to sort brasses ?  Brass looks relatively easy but how about gun metal; bronze; phos
      bronze; aluminium bronze etc ?
      Edited By Colin G on 11/02/2012 19:56:52
      Colin G
        @coling
        #87207
        JohnF
          @johnf59703
          Hi Colin, not the easiest thing to do if you are inexpearienced but a few pointers are as follows:-
          Brass is fairly easy and if you machine it it will cut with fine swarf that is in small pieces
          Gunmetal, look at the bar it usually has a slightly speckled appearance — not definative only a guide, it is generally softer than brass and adifferent colour
          Bronze is a coppery colour but much harder than copper
          Ally bronze, almost identical in colour to Admiralty brass — nice yellow colour but it is much harder to machine and the swarf comse off in spiral or contiuous string [assuming you are not using a chip breaker] The outside of the bar willl probably not show the oxidation associated with brass.
          Beware of Aluminium bronze it generally does not make good bearings but it is highly corrosion resistant.
          Hope this helps a little
          Gordon W
            @gordonw
            I was given a 6ft length of 3/4" dia. rod, the man said it was "electrical brass". I can find no references for this, I've been using it for general purposes, spacers etc. but would like to know if it is anything special, it machines much like ordinary brass but maybe a bit tougher. It did origenally come from an electrical wholesaler. Any ideas?
            #87331
            Colin G
              @coling
              Thanks to JohnF for your reply to my question. It was interesting to see that you were the only person to be able to give a response when it has had over 500 viewings. If anyone can add to your answer then please do not be shy! So thanks again John.
              Colin G.
              #87333
              Russell Eberhardt
                @russelleberhardt48058
                As John said, it is not easy.
                Brass consists of an alloy of copper and zinc sometimes with a bit of lead to make machining easier.
                Bronze (which includes gun metal) is primarily an alloy of copper and tin but usually with some zinc and other metals added.
                One test John hasn't mentioned is to put a drop of hydrochloric acid on it and look at the colour change. Brass will go pink. Bronze will still change colour depending on the amount of zinc present but will be paler.
                Short of a full chemical analysis if you have a critical application it is safest to buy known new material.
                Russell.
                #87336
                Keith Wardill 1
                  @keithwardill1
                  Hi, Colin,
                  I'm not surprised at the lack of informed response – I asked much the same question in the forum something like a year ago – and gots lots of hypotheses, but no real answer – the metal I wanted to identify was eventually chucked into the 'odds and sods' bin, and the project is suspended until I can get hold of suitable material.
                  #87337
                  Keith Wardill 1
                    @keithwardill1
                    Hi, Colin,
                    Some more info – try googling 'identifying brass and bronze' – ther is some useful info there, e.g http://eurekaifoundit.us/antique/metals.html
                    #87339
                    MICHAEL WILLIAMS
                      @michaelwilliams41215
                      There have never been many responses on this subject because there is really not much to say . Real world engineers and probably many home workshop people can distinguish between most of the common copper based metals almost intuitively .
                      Get yourself some known scraps of the different metals and get to recognise the colour of freshly exposed surfaces of each sample . Then try turning , drilling , soft soldering and silver soldering each sample .
                      If you teach yourself to observe the properties of each material and process you'll be an expert at recognising common copper based metals in a week .
                      Michael Williams .
                      #87341
                      peter walton 1
                        @peterwalton1
                        I dont think there is a generic answer to this question as there are many many types of bronze!
                        In the 60's I spent many years in the copper industry where we made copper alloys and bronzes and in most case the only quick way was for our sampler to drill a piece and he could usually tell what the generic alloy was. He accomplished this by drilling into the sample with a half inch drill in a drill press. If the sample was brass then the colour would show the alloy and the hardness if it was a bronze but only analysis could definately determine the alloy.
                        Although some brasses with high tin as an impuruty would be as hard as nails so the drilling would fail but in the end analysis is the only true way.
                        You can now get hand held xray fluorescence machines that will show the alloy, a bit out of HSM range cost wise.
                        Sorry for the pessimistic tone but it really is a mine field on alloy determination.
                        see link http://www.spectro.com/pages/e/p010602_spectro_xsort_video.htm
                        Peter
                        Edited By peter walton on 16/03/2012 18:34:18
                        #92296
                        Noggin
                          @noggin
                          Late answer I know but this is the gospel – there is no sure way to visualy determine any metal grade.
                          You can send the material away for testing though I doubt it would be economic for most people.
                        Home Forums Materials Topics
