People seem to be close to the target. When the engine is in a ‘steady state’ the boiler produces steam with enough energy to propel the rain. If it stops, what happens?
The exhaust blower will stop as soon as the engine halts this will reduce both the intensity of the fire and the effciency of heat transfer through the tubes immediately. I think this latter effect will be the most immediate. But let’s assume that more energy still enters the boiler than it loses through radiation and conduction.
1 The temperature in the boiler rises. The energy from the fire goes into raising the temperature and pressure of the water in the boiler. the amount of steam reduces, but some is still produced as this allows the pressure of the steam to rise in proportion to the rising temperature.
2 When the pressure rises enough the safety valves blow. This carries away heat in the steam and also (as a result of the reduced pressure) allows the water to boil more freely, using more energy.
3 If the safety valves can’t pass enough steam, the temperature rises making heat transfer from the flues to the water even less efficent. Only if this doesn’t happen at a low enough pressure/temperature wil the boiler.
So, in short, the systems is designed to turn heat from the fire efficiently into energy in steam only when it is working; that is why an inefficient blower is needed to keep the fire in when stationary. I imagine that for a large stationary plant the fireman had to be a lot quicker with the dampers to manage the fire if the load dropped suddenly.
A little extra musing, I recall that Tom Walshaw tested one of his engines with a condenser and it ran quite happily with the boiler running at below atmospheric pressure. More proof that the laws of thermodynamics trump common sense
Edited By Stub Mandrel on 24/06/2011 20:41:10
