Peter that would act like a thread mill as per the description rather than a boring bar though you would also need the motion to be helical not just the cutter rotating on it's own axis, the axial feed rate would be 0.030" per rev and could "thread" a hole of any given diameter to that pitch and form subject to clearances.
Then again it may not be intended to produce a thread. If lowered into the hole and moved in a circular motion while spinning it could be used to cut serrations to the inside of a hole or outside of a part purely to form some type of key or grip.
Though as I said earlier doe snot look as though it is intended to be rotated quickly like a thread mill or any milling cutter
Edited By JasonB on 15/01/2023 20:46:04
