Soluble hard varnish that sticks tightly to metal?
Home Forums Materials Soluble hard varnish that sticks tightly to metal?
  • #30076
    John Aitken
      @johnaitken84086
      John Aitken
        @johnaitken84086
        I know this is a difficult one because I've been looking for months and only found one thing that might work but it will be £200.
        I do jewellery repair and especially a lot of metal finishing, so polishing, brushing, sanitising etc and sometimes I need to do this on intricate chains and straps. I have techniques for doing this but they could be better which is why I’m looking for some sort varnish or lacquer that I can masks of polished areas with then apply abrasives to the whole work piece then dissolve the varnish so the polished parts stay polished and brushed parts are brushed.
        I can and do use tape but it has its limits and is only so practice and is incredibly time consuming on some items. There are a few products aimed at the industry but they are useless to put it bluntly. They from a loose latex layer.
        I really appreciate any suggestions and would like to add I’m not looking for a different way of doing things I’m just asking if anyone knows of a protective coat that can be applied to metal that can then be dissolved in anything that won’t damage the metal. Thanks.
        #505080
          The obvious choice would seem to be Shellac
          John Aitken
            @johnaitken84086
            Posted by Michael Gilligan on 03/11/2020 10:31:13:
            I did consider that I was just worried the shellac would gunk all the abrasive dust and brushes together.
            #505084
            blowlamp
              @blowlamp
              Would epoxy paint followed (after polishing) by paint stripper work for this task?
              I found Wllko own brand paint stripper to be very effective againgst some Rustoleum twin-pack paint, which was quite abrasion resistant.
              Martin.
              #505091
              Dave Daniels
                @davedaniels93256
                Conformal Coating ?
                Sticks to clean copper PCB. Can be removed with cellulose thinner.
                Not sure how it would stand up to being abraded though.
                Other stuff that springs to mind is Rustin's Metal Lacquer.
                https://cpc.farnell.com/ambersil/6130004030/conformal-coating-acrylic-400ml/dp/SA02317
                D.
                Edited By Dave Daniels on 03/11/2020 11:12:26
                #505093
                Speedy Builder5
                  @speedybuilder5
                  We used to coat aircraft panels with a spray on blue "latex" which protected against scratches during manufacture, and then could be peeled off, but I think you have dismissed that as impracticable.
                  Cortec product VpCI®-372 ??
                  #505095
                  Dick H
                    @dickh
                    How about polystyrene (eg. CD case) or a bit of Lego (colourful ABS) dissolved in acetone to make a paint? Use acetone again to remove.
                    How hard are you abrading it?
                    #505096
                    Perko7
                      @perko7
                      I've heard of nail varnish being used for similar processes, dissolves in acetone.
                      #505102
                        Posted by John Aitken on 03/11/2020 10:34:51:
                        Sorry, John … I apparently don’t understand your ‘process’
                        … Could you please explain in more detail?
                        Shellac is hard and brittle; can be dissolved in Meths, and is the basis of traditional lacquers for metals.
                        John Aitken
                          @johnaitken84086
                          Lots of good ideas here. I shall try some out. Thanks.
                        Home Forums Materials Topics
