Posted by Michael-w on 31/03/2017 15:35:54:
I'm not sure if this is true but might you need a special kind of flux to get any metallurgical bond on stainless steel, a bit in the same way aluminium can't be soldered without a very aggressive type of flux (and the appropriate solder ofc)?
Always smells like pine resin when you burn flux.
Michael W
Edited By Michael-w on 31/03/2017 15:37:07
What is being suggested IS a more aggresive flux which IS suitable for stainless, from the Harris site:
"Harris Stay Brite® and Stay Brite® #8. Stay Clean is an active soldering flux. It works well on copper and brass but is more frequently used on base metals that require a more aggressive flux, such as steel, nickel, and stainless steel, (it is not suitable for aluminum or magnesium)."
The other two home brews will do the same thing.
Edited By JasonB on 31/03/2017 15:43:04
