Hi all,
I have been using our enforced confinement to make some progress on the rear wheels for a Minnie Traction. I have the spokes and strakes on and am at the point of soldering on the hub inner and outer plates to the hubs.
I am using the 60/40 Tin Lead Solder Paint from Cupalloys and a mapp blow torch.
The first wheel seemed to go ok – all be it with a bit of run-off onto the side of the hub which needs cleaning.
However the second wheel the plates are refusing to stick. The solder is running and there is some tinning around the edges but the plates just pop off once the bolt clamping them together is removed. I have had two attempts now with the same result.
Any suggestions as to what could be going wrong?
Would too much heat cause problems? (clearly too little heat could also an issue). Would using an oven be better than a blow torch?
Is cleanliness as important with the paint as it is with silver solder? If so what should i use to clean it. I have some citric acid pickle but would worry this would cause corrosion on the spokes.
Do the surfaces need to be in contact or should there be a small gap as is the case for sliver solder? Currently they are touching when clamped together – but I guess i could use a couple of center pops to create a small gap.
Any suggestions would be appreciated – a ton of work has gone into the wheel thus far and I'm worried that I will make a mess of it if I don't get this right soon.
Cheers
Dom
