Posted by Speedy Builder5 on 31/05/2020 12:46:33:
I was very disappointed with my ANTEX 15watt iron (replicable tip), it came with a cable more like an anaconda snake – far too stiff and inflexible especially when the workshop was cold. By comparison my old Henly Solon 25watt (30 + years old has a beautifully flexible lead, tip held in by a small split pin. – Progress !
Edited By Speedy Builder5 on 31/05/2020 12:48:04
Many low voltage irons come with silicone mega-floppy leads and you used to be able to buy these as replacements for mains powered irons as well. I bought a couple years ago and have only needed to fit the first to the iron I keep in my tool case (I use a temperature controlled low voltage iron on the bench)
These don't seem to be available any more, but the cable itself is from eBay. So I suggest the answer might be to change your cable from the PVC (aka anaconda) standard one.
Regarding the Solon, the ideal tool for replacing diodes in Lucas ACR alternator diode packs was a 65Watt Solon, heated up on the bar of a 2 bar electric fire for a bit of extra oomph!
Edited By Nick Clarke 3 on 31/05/2020 13:08:03
