Posted by Paul Lousick on 21/04/2021 23:53:06:
A reference for improving our soldering techniques.
NASA Technical Standard: Soldered Electrical Connections
That document brought back a few memories.
In 1984 myself and another Australian Army member were selected to join six RAAF technicians to undergo training as High Reliability Hand Soldering Instructors (HRHS) Instructors.
This course was of about three weeks duration and our instructor was NASA certified.
The Australian military has a lot of very expensive high-tech equipment and the maintenance and repair techniques are therefore to be undertaken to the highest possible standards.
My area was RADAR/microwave equipment and air defence systems, while many of the RAAF blokes worked with aviation electronics. (No room for errors)
Even the basic preparation of a component required the correct tools and techniques, from lead cleaning and bending tools (of the correct radius) to a small carbide tipped shear tool (never wire cutters – they can send a mechanical shock into delicate components).
Other equipment included a calibrated temperature controlled soldering station, a comprehensive selection of tips, visual inspection equipment, solder pots, liquid resin flux, PWB Printed Wiring Board) holders and many other essential tools.
Even the preparation and handling of solder was carefully controlled. For a start, it comes in many sizes and much of our work involved using reels of 0.020" and 0.050" solder (that incidentally had traceabilty documentation).
After selecting the appropriate grade of solder, the working length was then cleaned with a white cloth dampened with isopropyl alcohol. The amount of black gunk that comes off is amazing. (Try it)
After completing a joint it is then carefully inspected before commencing another joint. The molten end of the solder is snipped-off to expose a fresh resin core before commencing another joint (as the composition of the molten 'blob' is unknown and one requires that the resin flow is immediate.
There is heaps more, anybody interested should study the document that Paul linked to.
At the end of the course we were offered a sample student PWB to assemble or we could submit our own project if of similar difficulty. I chose a 364K memory expansion board with multiple I/O ports for my Z80 computer.
It passed and is still working well 38 years later, no solder joints have failed.
* Danny *
