Hi Eckart.
Any problems associated with silver soldering are due tothe fact that the lead in the bronze ia not alloyed but is present as free lead. It is present as discrete lead inclusions.
When heated, those on the surface melts. When the silver solder melts later, the molten silver solder dissolves it and and alters the composition of the silver solder.
The silver solder becomes less fluid and penetrating.
Overcome the problem by increasing the joint gap and so increasing the volume of silver solder. This dilutes the effect of dissolving the lead. Result ? Better, stronger joints.
Of course, if the operating conditions allow it, you can always use a tin lead or tin copper soft solder.
For more information**LINK**
regards
Keith
