Soldering a main-bearing stand.
Home Forums Beginners questions Soldering a main-bearing stand.
  • #612784
    Bob Unitt 1
      @bobunitt1
      Whilst I'm not exactly a beginner, this is something I've never actually done before, so I'd like to be sure I've got it right.
      I have to temporarily solder together the main bearing stand and the main bearing cap, prior to drilling and boring the bearing-hole. Am I correct in thinking I should tin both relevant faces, and then clamp them together and reheat to join them ?
      Bob Unitt 1
        @bobunitt1
        #612785
        bernard towers
          @bernardtowers37738
          Or bolt it together with its proper fixings
          #612787
          Anonymous
            Never worked for me, the soft solder is too weak. I'd agree with Bernard, use mechanical fixings. This picture shows boring bearings, but is equally applicable if the bearing stand and bearing cap hole is round:
            #612792
            Bob Unitt 1
              @bobunitt1
              Posted by bernard towers on 08/09/2022 11:51:10:
              I'll try that, thanks.
              #612793
              Bob Unitt 1
                @bobunitt1
                Posted by Andrew Johnston on 08/09/2022 12:11:06:
                Your picture shows a separate bearing held together by the housing, whereas mine is drilled into the housing itself (it's on a Kennions' 'Tina' ), does that make any difference ?
                Edited By Bob Unitt 1 on 08/09/2022 13:45:24
                Edited By Bob Unitt 1 on 08/09/2022 13:46:37
                Edited By Bob Unitt 1 on 08/09/2022 13:46:53
                Edited By Bob Unitt 1 on 08/09/2022 13:47:15
                #612799
                Ramon Wilson
                  @ramonwilson3
                  Hi Bob the unit you require for Tina is much smaller than the bearing block that Andrew shows.
                  I have soldered together all the bearing blocks for the engines I have made without any issues save one where I held it in the mill for boring/reaming with the split line across the vise, not longitudinally. The block parted with the reaming pressure.
                  I put a series of images in My Albums under the title 'Making Bearing Brasses – the principle is just the same for a one piece unit which the Tina has.  Maybe that's worth a look? I'm not sure how to put a link to that so just take a look at photos under the user name
                  Here's the last image in that album – much smaller than the Tina I would think
                  Hope that helps – Tug
                  Edited By Ramon Wilson on 08/09/2022 14:25:22
                  #612803
                    On separate bearings I tin and solder large ones or use solder paste on smaller ones and provided you take it easy with the cutting forces and any heat generated they stay together OK
                    However as Tina is not like the ones Ramon and Andrew show because the bearing is part of the gun metal pedestal and cap I would machine the mating faces of the pedestal and cap then drill and tap as required before screwing them together and then machine the assembly making sure to mark them before taking apart so you put the back the right way.
                    #612921
                    Bob Unitt 1
                      @bobunitt1
                      Posted by JasonB on 08/09/2022 14:51:11:
                      Sounds like a plan, I'll try it that way – thanks.
                      #612943
                      Huub
                        @huub
                        I use 3% silver 97% tin (common lead free plumbers tin) for (soft) soldering HSS toolbits on steel tool holders for making grooving, parting and threading tools.
