Not sure of the wisdom of a drive fit ? If heating is correct then the capilliary and surface tension will pull the tube plate into the centre and maintain an equal gap all round, all be it only may be 3 or 4 thou. The harder part is to hold the tube plate in place in the shell, there are many ways. If the soldering is sound there will be a very small fillet, the joint will be filled by solder and therefore steam tight. Good luck Noel.
