Soldering 304 grade stainless steel
Home Forums Materials Soldering 304 grade stainless steel
  • #502069
    Andy Brocklehurst
      @andybrocklehurst85292
      Hope I’ve posted this in the right place but has anyone had much experience in soldering 304 ss? If so what’s the best flux and solder to use.
      Ive been told 304 is difficult to solder.
      Thanks
      Andy Brocklehurst
        #502074
        Peter Krogh
          @peterkrogh76576
          95% tin, 5% silver melts at 430 F. and was designed for 3xx food grade soldering. It's very much stronger than tin/lead solder and doesn't fatigue fail. It also works perfectly for soldering copper, brass, steel, bronze, etc.
          Very easy to use, wets out very nicely, and doesn't oxidize.
          The flux is an acid liquid.
          Both should be available at any welding supply store.
          DO NOT confuse this with the tin/zinc solders sold for copper 'lead free' joins. Tin/zinc is a horrible solder!
          Edited By Peter Krogh on 18/10/2020 21:03:50
          #502115
          Keith Hale
            @keithhale68713
            Hi Andy,
            See personal message
            Keith
          Home Forums Materials Topics
