Not really an electronics question but related. I'm trying to refine my technique for making pendulum suspension springs. Basically these are a strip of beryllium copper about 16mm wide which have thick brass "chops" soldered on each side of each end for mounting. The active length of the spring in between the chops is a few mm. The soldering problem is to prevent solder squeezing out from the chops when molten and forming littlee blobs on the active surface that could affect the uniformity of the bending. So I would like to put something on the spring surface between the chops that will inhibit solder wetting. This is the same sort of requirement as a "solder resist" on a PCB except that I will want to remove it after soldering.
Does anyone have any ideas for what I could use please? I've seen Tippex mentioned I think, I'm not even sure if that's still made! Soldering by the way is using electronic silver solder, either cored wire or paste.
