Hello all
i am having problems soldering a brass tube to a small mild steel frame. I am using TSC A8 stainless steel flux and a small micro torch. I did a test on a small piece of tube soldered to a mild steel washer – but now when I try the same materials on the actual parts – it won’t have it. The solder seems to stick to the steel and also to the brass – but then instantly falls apart so a bond is not being made.
What am I doing wrong? Both parts are cleaned with emery then 99% isopropyl.
Is there a better flux or a particular solder you could recommend?
thanks in advance
Margaret
